Werbeforum Hier kann nach Lust und Laune geworben werden. Bitte auch hier die Regeln und Nutzungsbedingungen beachten! |
Verkaufe folgenden,
unbeschädigten rechtdrehenden 4 Blatt Edelstahlprop: Hydromotive HC-CL19R 19" Steigung, 38cm oder 14,96 Inch Durchmesser Nabe passt auf Alpa und Bravo Antriebe Hier ein Auszug vom Anbieter: Hydromotive Quad IV Monster Marine -> Props -> Hydromotive Quad IV The Intimidator Quad IV propellers are designed primarily for single and twin engine sport boats. Boats with good natural bow lift, pad bottom boats, both single and double ventilated step bottom hulls and air entrapment hulls are perfect candidates for the Intimidator Quad IV propellers. Unmatched mid-range acceleration and blistering top speeds are trademarks of the Quad IV in both the pleasure and race arenas. These propellers are available in both right-hand and counter-rotation, and pitch ranges in every inch from 19" to 34". At 15 1/2" in diameter, these propellers perform quite well with high "X" dimensions and are currently manufactured with a built-in flare ring to improve hole-shot and mid-range cruise speed. The higher pitches are also available, from 28" to 34", in 16" diameter with slightly more blade area, allowing for extremely high "X" dimensions. Quad IV propellers are polished, balanced and more importantly, are all heat treated. Our manufacturing techniques and refinements over the years have greatly increased blade strength and fatigue resistance in some of the most punishing applications as is evidenced in our success in off shore racing. These propellers are available in the standard configuration for the Mercury TRS and Bravo drives as well as for the Bravo I XR drive with the large shaft. Our success in Factory I and II racing and our current kilo records assure you that our Intimidator Quad IV propellers have no equal. ITEM # DESCRIPTION PRICE COLOR QTY 569 Hydromotive Quad IV $593.95 ![]() Preis: 270 Euro. Anfragen bitte per PN oder E-Mail Gruß Thomas Geändert von Harleyschrotter (25.06.2012 um 12:13 Uhr) |
Kein Bedarf?
Kennt warscheinlich kaum einer.
Hilfreich wäre noch die Angabe, auf was für einem Boot das Teil gelaufen hat.
Gruß Jörg ------------------------------------------------ Jeder muss an was Glauben - Ich glaub, ich geh noch einen trinken. |
auch der Umfang wäre hilfreich
![]() nicht nur die Steigung.
Bye Dirk "Brain 1.0 (die Vollversion, nicht die limitierte Sharewarevariante, die viele im Einsatz haben) ist wohl immer noch der beste Schutz." ![]() |
Welche Narbe bzw Aufnahme hat das gute Stück.
Flo-Torq 1 oder ? bzw fest eingepresst bzw passt das auf den TR mit dicker Welle? gruss andre
Schreibfehler bitte ich zu Entschuldigen. Bin Staatlich geprüfter Legasteniker,Beglaubigte Abschrift kann gegen Erstattung der Gebühren vorgelegt werden. |
![]() Zitat:
Umfang ?!?
Noch nie gehört das irgendwo der Umfang angegeben wird. Soll ich den wirklich messen? Ansonsten wie bereits beschrieben, passt auf Bravo, wahrscheinlich auch auf nen Alpha (wenn der Durchmesser nicht zu groß ist) und auf TRS Antriebe. Der Prop war auf einer Sea Ray Pachanga. Gruß Thomas |
Themen-Optionen | |
