Alt 25.03.2008, 08:58
Benutzerbild von Magic Sound
Magic Sound Magic Sound ist offline
Standard Glastron V 184 Baunummer
Liebe Forum User,
wer kann mir sagen, wo man an einer Glastron V 184 eine Bau- oder Seriennummer findet. Es geht darum, dass das Boot an der Elbe registriert werden soll und die Papiere zeigen leider keine Baunummer auf.
Alt 25.03.2008, 09:10
Benutzerbild von Stephan-HB
Boot: Aphrodite 29/Hanse 291
11.809 Danke in 4.176 Beiträgen
www.classicglastron.com sagt:
From a letter from Glastron: "During the 60's, Glastron HIN's had six digits, and the the third number from the left was the year. If the hull number on the outside of the transom is missing or not legible, try looking on the underside of the dash near the steering column...There often was a hidden one there. "
"Boats that were manufactured from 1970 - 1973 carried a seven digit number. The fourth number from left indicates the year of manufacture. "
In 1973, Glastron starting using letters (GLA...) in the Hull Numbers.Prior to that, the early 70's were just seven numbers, with the fourth number from the left being the year (4322414 would be 1972). Starting in 1973 we were required to use prefixes. Using the prefix you can determine the location the boat was built. Then the seven digit id number will follow. A single letter and 2 or 3 more numbers which will tell you the year of manufacture. These procedures are in accordance with coast guard federal regulations"
Note that from 1973 forward hull ID numbers were stamped into the rear of the boat. This was federallyrequired for all '73 and later boats. This is good because the number will always be there and easily read in most cases.You can contact the factory Customer Service representative Jerome Haggerty for more help with serial numbersand other factory information
Nelson Mandela
Alt 25.03.2008, 09:12
Wenn es ein Spanier ist, dann im Heck suchen und hoffen, dass sie nicht einer Restauration zum Opfer gefallen ist...
Nelson Mandela
Alt 25.03.2008, 11:08
Fraenkie Fraenkie ist offline
16.545 Danke in 8.987 Beiträgen
Nummer hinten Steuerbord unter der Scheuerleiste.
Hits:	264
Größe:	54,7 KB
Alt 25.03.2008, 11:56
Thomas S Thomas S ist gerade online
Boot: Sea Ray 265 DAE
6.919 Danke in 2.351 Beiträgen
guckst Du hier: ein bischen runterscrollen und dann Identyfying Glastrons http://www.classicglastron.com/
Gruß Thomas S
Alle Zeitangaben in WEZ +1. Es ist jetzt 17:29 Uhr.
