Volvo B230, welcher AQ Motor
Hallo Leute,
ich habe einen Volvo B230 Motor. Kann mir jemand sagen, um welchen Typ es sich vergleichbar als VOLVO-Penta AQ ?? handelt? Da ich einen alte 2 Mot. Sunseeker habe, such ich noch einen gleichen Motor. Gruss Thomas PS. Bestellt mal etwas besseres Wetter, wir haben schliesslich noch Sommer |
Gruß Jörg |
MFG René
Ich selbst habe den 230B. Hier die Unterschiede der Modellreihe :
"The B230 motor was available as a penta marine engine in 3 variations. The AQ131 was a B230 with a single carb. The AQ151 was the stroked B230 with the 86mm crank making it a 2.5 litre running twin carbs and the AQ171 was the stroked B230 with the 16 valve head also running twin carbs. I have the Penta manual on these motors and they all do exist. It won't be that easy to find them however. There is also a Super Marine block which is very similar to the R block. It can be bored up to 99mm successfully. There was a guy running a sprint car of some sorts with the Super Marine block bored to 97mm with the 86mm stroked crank. It had a 14:1 compression ratio running on methanol putting out 340 Horsepower and apparently in a class of its own."
