Alt 07.02.2012, 12:07
Shekastui Shekastui ist offline
Boot: Kazanka-M, nearly all Soviet boat engines; Mercury 2.5; Forelle 6
43 Danke in 8 Beiträgen
Standard Help needed with Forelle 6
Hello to everyone. Unfortunately I don't know German language, thats why I will write English, I hope that you'll forgive me. I live in Russia and I own Forelle 6 produced in 1967. The engine works perfectly as all German engines usually do, but I have great problems with chocks and mostly with rubber collars in reducing gear. It's impossible to take them out of the gear without ruining them, that's why I can't define the scales and find the substitution. I thought that probably somebody in Germany has this scales (or can measure them) or catalogue of parts or probably even scheme of that engine. What is more the reducing gear was repaired and some parts were replaced with soviet parts, now they are also spoiled and no longer produced. But I can't find out how that gear looked in original with original parts, not soviet, probably somebody has a photo of the inside? I will be very greatful if you help me with at least one of the listed problems.
Alt 07.02.2012, 12:42
Here are the photos of my engine. Also you can find a video with it working on YouTube. It is called "Forelle 6 at work".
Alt 07.02.2012, 13:38
Benutzerbild von Jan-Maat-79
Jan-Maat-79 Jan-Maat-79 ist offline
Boot: V-SPRINT in Resto
Rufzeichen oder MMSI: Nicht gucken - Nur anfassen!
790 Danke in 249 Beiträgen
Dobre!
Here is a picture and a link, to the whole manual!
http://www.faltbootbasteln.de/fbb-fo...senborder.html
Hits:	109
Größe:	63,6 KB
Tschüss Ahoi
Daniel
Global warming is killing lighthouses!!!
Alt 07.02.2012, 13:49
Benutzerbild von dumperjack
dumperjack dumperjack ist offline
2.173 Danke in 1.381 Beiträgen
Надеюсь, это поможет вам в дальнейшем.....
Hits:	120
Größe:	37,6 KB
ID:	338394   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	124
Größe:	92,6 KB
ID:	338395   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	121
Größe:	94,0 KB
Hits:	110
Größe:	46,2 KB
ID:	338397   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	136
Größe:	68,4 KB
ID:	338398   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	134
Größe:	91,8 KB
Hits:	121
Größe:	97,3 KB
Gruß Frank
Mein Vater lehrte mich immer erst das instandsetzen, später dann die Nutzung ... Danke, Väterchen
http://www.boote-forum.de/image.php?type=sigpic&userid=2079&dateline=1175421  811 http://www.boote-forum.de/showthread.php?p=1860996#post1860996
Alt 07.02.2012, 13:51
Thank you. But I've already seen it. Unfortunately there is no detailed scheme of the reducing gear and no scales of needed parts. Only numbers of some parts are given, but now it is difficult to find the correlation between these numbers and scales.
Alt 07.02.2012, 13:52
dumperjack, огромное спасибо!!! Это мне очень поможет, это именно то, что я искал!
Alt 07.02.2012, 14:16
Я знаю ....
Добро пожаловать на форум
http://www.youtube.com/watch?v=Ir_DOt4RloU
Hits:	123
Größe:	47,4 KB
Gruß Frank
Geändert von dumperjack (07.02.2012 um 14:42 Uhr) Grund: Bildanhang/Прикрепленное изображение
Alt 07.02.2012, 14:23
Спасибо!
Alt 07.02.2012, 18:26
dumperjack, and where did you get these schemes? Do you also own Forelle? I will write in English from now on, so that other people could undrestand what we are talking about.
Alt 11.02.2012, 01:51
Sorry, I've only just seen Your Post.
I have almost all East German and Russian Engines.
But also Engines from the U.S. and the other Eastern Bloc Countries.
Gruß Frank
Alt 12.02.2012, 10:12
Cool! I also own many russian engines, they are listede in my profile. I'm going to get more of them to create some kind of museum with working exhibits. And have you examined the schemes of Forelle? Why some of positions are repeated twice? For examle in scheme 032-5 part number 15 is listed twice with different scales.
Alt 12.02.2012, 20:50
Two pictures, two parts lists ....
I have separated the lists so that the resolution is to read better.
Gruß Frank
Alt 12.02.2012, 21:07
Sorry, misunderstood.
Position 13 = there are two different stages of assembly (Insertion in the production/pre-assembly)
Position 15 = This is a needle bearing of 2 components.
Gruß Frank
Alt 12.02.2012, 21:22
Forget everything ...
We need a different parts list.
Hits:	99
Größe:	39,0 KB
Gruß Frank
Alt 12.02.2012, 21:51
I had scanned the lists of 1969, we need the list of 1966.
Hits:	128
Größe:	52,4 KB
ID:	339575   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	111
Größe:	33,2 KB
Gruß Frank
Alt 12.02.2012, 22:00
Now the correct information.
Hits:	114
Größe:	56,1 KB
ID:	339579   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	113
Größe:	56,6 KB
ID:	339581   Klicken Sie auf die Grafik für eine größere Ansicht
Hits:	110
Größe:	46,8 KB
Hits:	110
Größe:	55,4 KB
Gruß Frank
Alt 13.02.2012, 21:23
You are god of boat engines or what? Where did you get all this so quickly?)))) Thanks a lot! I definitely owe you a lot of beer! Now everything is clear, cause I broke my brains trying to understand the previous schemes. My engine is 450 km from me at the moment, but I remember that it is definitely different.
Geändert von Shekastui (14.02.2012 um 10:12 Uhr)
Alt 15.02.2012, 17:51
dumperjack, execuse me for bothering you and for being greedy. But I thought that you might have the scheme of the engine as well. If you have one and it is not difficult for you, please can you post it here? Cause I've found the needed chocks and collars in St Petersburg and I'm going to order them, so I thought that it will be clever to order chocks and collars for the engine too.
Alle Zeitangaben in WEZ +1. Es ist jetzt 16:55 Uhr.
