Alt 22.05.2014, 21:54
monette999 monette999 ist offline
20 Danke in 16 Beiträgen
Standard Elektrische Benzinpumpe Carter Rotary Vane
Hallo Forum,
wer kann mir sagen ob eine elektrische Carter P4594 Pumpe OK fuer Marine Applikationen ist. Der Hersteller wirbt mit einer Marine Freigabe.
Diese Pumpen haben keine Points (Kontaktlos??) und keine Wellendichtungen die Leck schlagen koennen.
Sind diese Pumpen Saugpumpen oder Druckpumpen.
Danke fuer eure Beitraege.
Robert
These universal rotary vane electric fuel pumps from Carter operate using leaded and unleaded gasoline, gasohol, and fuel boosters. They have an internal pressure-regulating valve, and feature free-flow fuel delivery. These pumps have no points to burn out, and no shaft seals to leak or deteriorate.
Carter® In-Line Universal Electric Fuel Pumps
Our in-line universal electric fuel pumps are suitable for many domestic and imported passenger cars, trucks, marine and industrial engines. These pumps come in a variety of configurations, depending on need.
Rotary vane design
Originally created for military use, this design has been in production longer than any other Carter model. Rotating vanes driven by a heavy-duty wet motor deliver pressure from 4 to 18 psi at a flow rate of up to 100 gallons per hour. This provides excellent lift and prime capability. The pump is available in 6-, 12- and 24-volt versions. It is appropriate for RV, marine, agricultural, industrial and performance applications.
Hits:	161
Größe:	25,1 KB
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:00 Uhr.
